-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Eight Blades vs. Six (https://www.offshoreonly.com/forums/prop-talk/269287-eight-blades-vs-six.html)
MR252SS 01-23-2012 11:09 AM
Considering replacing stock three blade 28p props on Formula 252 454 Bravo III with four blade 28p. Will there be noticable increased performance? Should I consider different pitch? Anyone using Hill Signature props?
A.O. Razor 01-23-2012 11:17 AM
First off. Way too little info here for us to say anything. Current max GPS speed @ ? rpms, gear ratio ect. What 454 is it? More blades in a BIII setup will rearely give you more speed. Call Brett at Bblades. I know he's a fan of the 3+3s. The 4+3 is also a possiblillity. I did not know they did a 4+4. There is the XR BIII props as well. BIII props can, as well as other props, be labbed for custom performance. Have no experience with the Hill props.
MR252SS 01-24-2012 09:09 AM
Thanks for suggestion, will contact Brett at BBlades prior to change. The gear ratio is 1:81, the motor 454 LX MPI 330 hp, max WOT 4600 RPM, and the speed 58ish mph. was not only looking for a little speed, but better planing time. Was not sure of benefits of 4 blades vs. 3 blades.
bbladesprops 01-24-2012 05:09 PM
Your slip % is just under 14. A very acceptable number.
3x3's have more modification abilitys.
The 4x4 Signature propeller has proven to be a great low end and mid range upgrade. We carry them and love what they were intended for. You may lose 2 mph on top end with these. $599 each
Call and we can discuss more in depth the options you have.
Brett
MR252SS 01-25-2012 09:54 AM
Thanks Brett, great info, will be in touch prior to change!!
