Expert Help please Prop 21 foot Boat
Have project boat(1989 scarab excel) that is almost done, came with fresh alpha drive and 19 pitch 3 blade ss prop. Motor was cracked, so got short block 383 , with BM MOTOWN 23° ALUMINUM HEADS, demon 650 , stock merc dist. , thru hull corsa exhaust. Just need advise on prop size, I run the local river , with myself and one other person. Would like to see top end in the 64-66 range. Thanks in advance. I have a 4 blade ss set off my Formula 24 pitch.....too much for an alpha?
I think a 3 blade high rake SS prop will serve you best. Try the one you have and let us know if you wish to test any others.
Brett |
test run results
boat ran 53 mph on gps with 3/4 tank of fuel, 650 lbs of people , looks like I need to go to a 23 pitch. Still plenty of power left in the stick
Let us know if you need some test props.
Brett |
you have a PM
go up in prop size? 21 foot with 383cu 23 pitch mirage
ran yesterday on the bay, WOT is 55 on the gps, 3/4 tank and two guys , can't trim too much at all, loosing bite at higher rpm's. can I run a 4 blade? maybe 24 on the alpha? Thanks
What is your RPM at WOT?
5000k thanks
So you are at 5000 rpm with a 23" pitch prop and 55 mph gps?
What is your drive ratio? |
CRG,
did you send me a PM? Sorry, I was at Desert storm for the last week and I want to make sure I didn't miss anything. Brett |
| All times are GMT -5. The time now is 09:40 PM. |
