-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   oil cooler and oil thermostat ? (https://www.offshoreonly.com/forums/prop-talk/278306-oil-cooler-oil-thermostat.html)
cheetah29 06-09-2012 07:37 PM
I had an oil cooler failure and am going to replace it with a new one but
my question is I am running about 650 hp and had a stock mercruiser oil cooler / power steering cooler
and also running no water thermostat and had no oil temp
So i was thinking do i need the Highperformance Oil cooler and run a oil thermostat or run the stock replacement with the thermostat
Any One have an Idea
ROB FREEMAN 06-10-2012 09:57 PM
at 650 im guessing you will need a larger cooler . plus regulated oil temps are always a good thing sir ...good luck
