Prop question baja h2x 7.4 mpi
I currently run a 23 mirage + and see about 62 mph at wot at 4300 rpm actually see 4300 at 3/4 throttle with no increase when I pin it. Seems to take a bit to get on plane when loaded up and feels like it carries the bow a little high. What king of change would I see with switching to a bravo 22 p? Was thinking of picking up a used one to try
Thanks Larry |
Originally Posted by Z06vette1
(Post 3760062)
Thanks Larry |
Originally Posted by fleg1
(Post 3760263)
First off I think the prop is too big!! I believe the WOT rpm is 4600 to 4800 so I would be looking for a 21p Mirage.. A 22 Bravo I don't think will spin the rpm's you need unless you had it labbed..
Definitely sounds overpitched to me.... slow holeshot & low rpm on top end. I think the 21 Mirage is good advise. Thanks, Tim Bostic Hoss Marine Props |
| All times are GMT -5. The time now is 03:30 PM. |
