-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Sea ray 280 twin bravo 1 drives in need of better props (https://www.offshoreonly.com/forums/prop-talk/284050-sea-ray-280-twin-bravo-1-drives-need-better-props.html)
Eddiejaimes 09-03-2012 12:47 PM
Good morning im new to the forum even though i dont have a power boat i bougth the closest familly friendly boat that i can find ( also on my budget) i ended up with a 2000 mint sea ray 280 bowrider with the sport package twin v8 5.7 and bravo ones' the props are vengance 143/4 x 19 the boat jumps out of the hole and top speed is arroun 56 or so, im looking to get closer to 60 or so, im planing to add the corsa exaust and better props now it cruises at 3500 rpm arroun 38-40 or so top rpm are rigth at 5000 maybe a bit more depending of the trim any input will be greatlly apreciated thanks for your time in advanceˇ
bbladesprops 09-06-2012 05:52 PM
Lab Finished 3 blade props will help you gain some speed and work on your hull.
We can run some numbers if you would like to give us a call.
Thanks,
Brett
