-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   best prop for cat twin OB's (https://www.offshoreonly.com/forums/prop-talk/284599-best-prop-cat-twin-obs.html)
r015 09-11-2012 12:19 AM
Have a Skater 28' w/280's anyone tried anything else other than 3 blade merc cleavers, like maybe merc ET's ?
Any other combination work well?
Maritime_Eng 09-11-2012 06:10 AM
Do a search on screamandfly.com
There is a ton of information on setup of 28 skaters over there.
bbladesprops 09-17-2012 08:21 PM
BBLADES Blasters.
Hands down.
Everyday props, Labbed BBLADES Bravo 1 OB's.
I know, I'm a advertiser but, no BS.
Brett
berns29scarab 09-26-2012 11:21 PM
i was spinning 15x32 labbed 3 blade cleavers worked by bblades on my 30 spectre
4mulafastech 09-29-2012 03:52 PM
Mazco OS Cleavers worked great on my twin outboard Talon.
r015 10-04-2012 06:45 PM
Originally Posted by bbladesprops (Post 3778739)
BBLADES Blasters.
Hands down.
Brett
Heard Bravo 1's don't plane well from more nthan a couple sources even with vent holes and are not as fast as 3 blade cleavers?
I have 3 blade cleavers and they plane great and have good top end, but slow acceleration .Trying to get the one thing they don't have is to accel,why not Lighting ET's?? Not durable enough?
bbladesprops 10-08-2012 11:53 AM
Lightning ET's will work fine.
Our 4 blade Blasters will be the better acceleration prop.
We have just adjusted the heat treat process to add more strength to the castings. We are validating the performance as we speak and should have full inventory levels of propellers in about 2 weeks.
We do have these propellers for testing prior to purchase.
Brett
r015 10-09-2012 05:08 PM
Thanks Brett,
Maybe we'll give them a test try in the spring,if they would accel better and only be couple mph slower would be ok,if you can out accel someone it takes a long time for them to catch back up.
Just seems like the 3 blade cleavers take a while to get all wound out,but they do handle great.
I have 14% slip would like to get that at least down to 12
How do the blasters compare to Merc ET 4 blades,i'm not and ET nut , just don't know what else to try and i know they work ok on singles for lake use.
Randy
bbladesprops 10-16-2012 03:21 PM
Blasters are a 1/4" smaller in diameter than the Pro ET with a different parabolic rake angle.
They are very fast and have great load carry capacity and planning characteristics.
Brett
