-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   difference between a hydro and a bravo 1 (https://www.offshoreonly.com/forums/prop-talk/285502-difference-between-hydro-bravo-1-a.html)
berns29scarab 09-26-2012 11:42 PM
what are the differences between the hydromotive 4 blade say a 27 pitch and a 28 pitch bravo 1 4 blade. single engine vbottom
excalibur82 09-27-2012 07:37 AM
I know they make a cleaver and a round ear..
berns29scarab 09-27-2012 09:15 AM
Was talking about how it affects boat. Stern lift or bow lift etc...stock bravo 1 4 blade to a hydro P seriers
POWERPLAY J 09-27-2012 09:27 AM
Bravo= bow lift
Hydro= stern lift
vtown 09-27-2012 06:18 PM
bravo 1 vs hydro p4x? Very similar prop....hydro has more rake (blades have higher angle of entry). This is supposed to give more bow lift. There is also more surface area so may give a little lift to the transom. better cruise and MAYBE better top end...that depends on your boat. Try it out and report back.
berns29scarab 09-28-2012 12:05 AM
thanks
bbladesprops 09-28-2012 04:26 PM
Hydro does not have more rake angle or blade area.
The Bravo 1 will react better to trim which can create less wetted surface area and decrease drag which can make you go faster.
The Hydromotive has more stern lift and on a set up that wants to run flat, it can be the better performer.
Brett
Advantage 27 09-28-2012 07:35 PM
Brett
Brett,
How about the Hydro Quad IV-X?
thanks
bbladesprops 09-30-2012 08:12 PM
Reversed engineered B1 with diferent TE cups. (copy.....not as good)
Truely
B
