25p Rev 4, I like it!!!
The boat:
1995 Python Vector 24 x 7 hull, 540 cid N/A engine approx 625 HP Results from a few different props: 24p Bravo 1: 5700 rpms and pretty stable 77 used prop 25p Mirage+ cut to 14" diameter: 5950 rpms 81.5 prop handles well just not enough pitch 26p Turbo txp: 5550 rpms chine walking bad 84 mph would slip bad on turns or if any weight was in boat 26p Turbo 1 5600 rpms chine walking 86 mph 2nd favorite prop and fastest, all around good prop, just chine walk problem 25p Rev 4 5700 rpms pretty stable 82.5 mph The Rev 4 is now my favorite prop of the bunch. It planes faster, has good cruise econ, and boat handles better at high speeds. Even though I lost 3 mph on top end. my 2 cents, Lee |
Originally Posted by Flying Tomato
(Post 3834699)
The boat:
Originally Posted by onesickpantera
(Post 3841187)
I love the Rev 4 on my boat. I would also try a Turbo Lightning 3-blade. More rake than the Turbo 1 but less than the TXP.
It's superior a standard Bravo in every way, top speed, acceleration and especially handling! I'm thinking of getting a labbed one, but need to test a few more things first. |
+1 on rev4. AMAZING acceleration. Helps fuel mileage. Really pushes boat along nicely/quickly at idle. For me I picked up 2 mph over the same pitch Mirage Plus.
Do these have removable hubs. Can I put my XR hubs in them? Do you have Pics?
Thanks Mark |
Originally Posted by MrCIG
(Post 3842109)
Thanks Mark |
Hi,
Rev4 25 labbed been my best prop. 81-82 mph at 6,500 - 6,600 rpms. Picked up 1,5 mph cutting tube down with 1,2 inch. Phantom 25 with Verado 350 sci. Great cruise too - 49 mph at 4,000, - 62 mph at 5,000 rpm. Milage 4,67 mpg at 4,000 rpm and 5 mpg at 3,500 rpm. Will test TxP this summer:) Cheers Toffen |
Originally Posted by Toffen
(Post 3843101)
Hi,
Hi,
The prop was balanced and had extra cup added so it can be surfaced higher. Unfortunately I bought the prop second hand so I have no figures before and after. However, I cut down the exhaust tube with 30 mm last spring - and that translated to 1.5 mph higher speed. Much more bowlift. Very good prop. Testet a stock Bravo one 26 prop. Much less bowlift. Can be surfaced higher (1,5 inch) before breaking over, but got substantial less speed. 76 mph vs 81 mph. Cheeers, Toffen |
Originally Posted by Racegirl3
Reason: Spam :-)
Edit: props are sold so this is not a round about way ad. |
