-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Power tech vs Bravo 1 (https://www.offshoreonly.com/forums/prop-talk/289634-power-tech-vs-bravo-1-a.html)
Scarab29 01-04-2013 07:26 AM
Looking for a set of props for my boat. What am I gaining or loosing between them both.. 32 Advantage MCOB with 496hos ..
bbladesprops 01-04-2013 03:07 PM
Ulimately testing is the only way to determine the differences.
My experience has been the Bravo 1 props are much more consistant in geometry and performance. They also respond to Labbing very well. If you want to spend a little less and have propulsion the PT is a viable option. Again, back to back testing is the only way to get exact numbers.
Brett
Scarab29 01-08-2013 06:04 AM
Thanks I will give them a try, They are cheap enough.
