-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Diameter increase? (https://www.offshoreonly.com/forums/prop-talk/290213-diameter-increase.html)
bwd 01-15-2013 11:05 PM
Diameter increase?
I have a set of labbed Bravo 1's that the dia has been cut some. Can that be returned or increased more?
himrod67 01-17-2013 02:30 PM
I asked the same question a little while back ( increase the diameter on my prop lower the slip ) I was told it cant be dun.
Drock78 01-17-2013 04:01 PM
kinda like cutting your hair...once its gone, its gone
FIXX 01-17-2013 07:09 PM
fixx
you can add a 1/8'' but that about it.any more wil brake off..
ROB FREEMAN 01-17-2013 08:56 PM
sell n buy differant .
bwd 01-17-2013 09:29 PM
These wheels were free, sort of, and are in the ball park of being a good rough water 85 mph wheel. I really did not know what was possible or was it worth experimenting.
bbladesprops 01-21-2013 11:17 AM
Without going through a annealing and heat treat process, the repair will most likely fail. We will a blade if required but not a entire propeller. (except in rare or unique cases)
The cost to do this really prohibits the value.
Better starting fresh.
Brett
bwd 01-24-2013 05:15 AM
Hey Bret, while I have your attention, and thanks for the input btw, I have another issue. This past spring I had Hering copy a set of Matt and Julie 6blds, which they said they could., (my first mistake). They basically worked like crap. They reworked them and I got a little more out of them, just barely enough speed though for my class. They also seem to have way to much bite as I'm going through drive parts now. I'm worried about thinning them too much to the point of breaking as they are not cheap. I wonder if I should start from scratch or rework something else. With all the drive repairs still to address the prop budjet is running a little low. The 6's are for sbi and the bravo was an opa idea. So not only do I need to resolve my 6bld problem but come up with a wheel to start off with opa. Brian
bbladesprops 01-24-2013 10:37 AM
bwd,
Reworking the Hering copy to perform better would not be the first time we did that.
Looks like this is a phone call situation. Why don't you call me when it is convienient for you.
Thank you,
Brett
