Volvo DuoProp Wrench?
Have heard a few different opinions--is the Volvo wrench the best or does someone know of a better solution for a tool to remove the forward prop nut on a Volvo DuoProp DPS drive?
I've heard it's rather simple to "make" your own taking a deep well socket and marking/grinding to the notches on the nut. Thoughts are appreciated. |
Originally Posted by Dave1972
(Post 3879922)
I have a spare DP wrench I'd sell
...and be prepared to fight, and cuss, and throw tools if the forward prop has welded itself to the hub....
Originally Posted by commandersander
(Post 3885107)
It's about a 450 upgrade.....but waaaaay worth it.
(Post 3885863)
Thats about the best deal i ever Regarding boat stuff. |
First time I saw the genuine Volvo tool I thought it to be pretty Mickey Mouse. They actually work pretty well. A lot less work buying one than sawing up a socket .BTW ,It would have to be one deep, deepwell socket to modify to fit over inner shaft. If you own a Volvo duo boat,you should also own the correct prop wrench ...Won't help you on seized splines though.
How would one go about getting the proper torque on the forward prop nut with a self-made rig? My boat yard had several self-made prop nut gizmos but none where made from sockets so no torque wrench connection.
Greg |
Originally Posted by 260BR
(Post 3897658)
Take the torque value, say 100 ft-lbs, and divide it by the length of your wrench, say 9" (.75'). 100/.75= 133 and this is the force you need to apply to the wrench. A longer wrench, cheater?, obviously makes this easier to do, but you'll need to account for its weight if it gets too long. Keep the wrench horizontal, parallel to earth, and the force going straight down to prevent any geometry errors. That's |
Originally Posted by Cole2534
(Post 3897803)
Here's how a torque value can be achieved without a dedicated torque wrench-
Take the torque value, say 100 ft-lbs, and divide it by the length of your wrench, say 9" (.75'). 100/.75= 133 and this is the force you need to apply to the wrench. A longer wrench, cheater?, obviously makes this easier to do, but you'll need to account for its weight if it gets too long. Keep the wrench horizontal, parallel to earth, and the force going straight down to prevent any geometry errors. That's Greg |
Oops.
...That's a field expedient method of calculated torque delivery. You can work the length and force to arrive where you need to. |
(Post 3897962)
Oops.
| All times are GMT -5. The time now is 12:46 AM. |
