-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Is this possible? (https://www.offshoreonly.com/forums/prop-talk/292927-possible.html)
Aasved 03-13-2013 01:04 AM
Is this possible?
I'm trying to figure out how good my props are on my 1997 29 fever with twin 502's. I just finished rebuilding the motors but want to see if the props are good to keep or should I try to send them to BBLades and have them tweaked a little or get new.
I bought the boat with the props so never really knew much about them.
Here is what I was running before the rebuilds and the speeds are accurate as far as I know. GPS on my boat and many others that have confirmed.
5000rpm 78 mph and 1.5 drives. running Hydromotive Q4 26 pitch. This figured out to be 4.96% slip on BBlades calculator. Is this possible?
Is this correct and if so is is it too low or to high for slip? What do you all think?
bbladesprops 03-14-2013 02:22 PM
It is possible but also unlikely.
9-10 would be excelent and more reasonable.
If the boat gets on plane well and carrys well your in a great spot.
The next move would be something like testing 28 Bravo 1's to determine if Labbing was a possibility.
Brett
