-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Would a Maximus 5 Blade Help me out?? (https://www.offshoreonly.com/forums/prop-talk/293621-would-maximus-5-blade-help-me-out.html)
TC G 03-27-2013 10:46 AM
I have a 27' Fountain with a 502, 415hp engine. I get a lot of blow-out on take off. Especially in oncoming seas. Not as bad in trailing seas. My question for the prop experts is: Do you think a Maximus 5 Blade would help me with this?
TCG
TC G 03-27-2013 10:47 AM
Forgot to mention that I am currently running a 24P Bravo 1.
JBoat 03-27-2013 01:11 PM
Do you have a drive shower. They cause that quite frequently.
TC G 03-27-2013 04:15 PM
I do have a drive shower.
bbladesprops 03-27-2013 05:05 PM
How deep is the prop shaft in relation to the bottom of the boat directly in front of it?
Brett
TC G 03-28-2013 08:20 AM
The boat is in storage and I won't have access to it for a couple of weeks. It's a stock setup in a 1997, 27' Fever if that helps.
bbladesprops 03-28-2013 11:19 AM
That vintage should have a realatively moderate X dimention. But, measuring it is the only way to know.
Brett
Griswald 03-28-2013 12:44 PM
'97 model is 17.25". i believe that makes the prop 6-7" below the keel
bbladesprops 03-28-2013 01:34 PM
Agreed but as we all know alot can happen in 16 years. Also, every identical boat can be different.
The 5 blade will definately help the planing but it may compromise the top speed due to drag and stern lift.
Brett
TC G 03-29-2013 08:41 AM
The boat has a stepped hull. Wouldn't stern lift be a major problem.
bbladesprops 03-29-2013 11:13 AM
Stern lift is a relative term.
Too much=bad.
not enough=bad.
Brett
Griff 04-02-2013 02:22 PM
The smallest pitch in a Maximus is 23" and generally you would need to drop down 2-3" going from a Bravo 1 4 blade.
To make a 23 Maximus work, it would probably need some diameter cut off and custom labbing to keep the rpms where you need them.
You may be better off having your current prop reworked with additional cupping.
HALLETT FAN 04-02-2013 03:15 PM
Originally Posted by griff (Post 3897368)
the smallest pitch in a maximus is 23" and generally you would need to drop down 2-3" going from a bravo 1 4 blade.
To make a 23 maximus work, it would probably need some diameter cut off and custom labbing to keep the rpms where you need them.
+1
bbladesprops 04-02-2013 03:39 PM
Quick side note. The Maximus smallest available casting is 24. Mercury Racing offers a 23 version but it is a Labbed propeller. We offer the same option in Labbed or stock but again the casting starts as 24 inches of pitch.
Griff is right that custom Labbing will most likely be needed.
There are other 5 blade propellers that may work as well. We have Hydromotive P5X's and Turbo OXP's for testing.
Thanks,
Brett
bwd 04-02-2013 05:12 PM
Brett
What exactly is the physical property of a prop that makes stern lift? Diffuser, rake, pitch, size, etc etc?
bbladesprops 04-02-2013 08:27 PM
Oh boy................
Every point of the geometry you mentioned makes a difference.
I would rather explain those attributes over the phone since it takes less time than writing a book. (which is literally what it would take)
There are all kinds of things including "X" dimension and hull design that also affect propeller stern lifting capacity.
Call anytime and I'll answer any questions you have.
Thank you,
Brett
bwd 04-03-2013 08:09 AM
I try not to bother people by calling them with questions and advice when I haven't done business with them even though I intend to. But if its a long answer, I'll call. I asked in the open figuring it was an interesting question. Thanks,
Brian
bbladesprops 04-03-2013 12:41 PM
bwd,
Thank you for the thought.
Anybody who is a regular to this forum knows I have been offering "free" propeller, boat setup, and performance information since the propeller forum began. Literally 8 years ago.
I have tried to educate people as well as market my business. ( we pay substantially yearly to advertise. Some people try to advertise without stepping up to the plate with money or even offering legitimate input. That's frustrating at times)
I think we have done pretty good at serving the people who visit this forum for information. I see certain people quoting my comments from years ago so I know BBLADES has been instrumental in helping the performance boating public come out of the "black magic" propeller days.
I do keep the special information secret. LOL
Call anytime. If I'm busy, Brad is my right hand man.
Brett
TC G 04-04-2013 03:49 PM
Thanks,
Brett
So given my situation what do you think would yeild the best results? 5 Blade prop of any manufacturer or getting my 24P Bravo 1 re-worked?
bbladesprops 04-04-2013 08:38 PM
At this point the best input I can give you is that over the years and with many 27's under our belt,
4 blade propellers at the correct "X" dimension have been the clear cut winner at overall performance.
Determining the specific goal you need helps to obtain the correct recipe.
Brett
mtm 04-07-2013 08:58 AM
prop
how old is your prop also has it had any work done to the prop ? if you start with a new prop might solve the problem
TCG
TC G 04-08-2013 03:22 PM
Not sure. I bought the boat used 2 years ago. The performance report shows that the boat was tested with a 22P Mach. When I bought the boat I was not given the Mach, so I'm not sure what happened to it. Don't know if the 24 Bravo has had anything done to it??
