-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Turning in vs turning out on V bottom?? (https://www.offshoreonly.com/forums/prop-talk/294312-turning-vs-turning-out-v-bottom.html)
JUPITER PULSARE 04-09-2013 10:17 AM
I've got a Checkmate 2800SX outboard with twin Mercury 2.4L 200's. I'm running the motors on Gill brackets with 24" of setback at 18" centers. Running a straight edge off the bottom, the bullets of my noseconed lower units are about even with the bottom. The boat is very easy to trim up and the bow gets a bit flighty in rough water (the cabin is gutted for the time being-I'll eventually recover all the seats/V-birth pads with new vinyl and reinstall the wetbar). I've got the boat set up turning the props out right now but I'm in the process of swapping the lowers to try turning the props in. I'm hoping to pickup a few mph and some stern lift...any suggestions??
bbladesprops 04-09-2013 12:45 PM
Hello,
I believe we have spoken a bit about this before but if not.
Inward rotation will create more bow lift and less stern lift (from a physics standpoint).
Ultimately your seat of the pants observations will determine which rotation you prefer and the propellers can be modified to assist the boats attitude from there.
Brett
JUPITER PULSARE 04-09-2013 02:01 PM
Originally Posted by bbladesprops (Post 3902040)
Hello,
Brett
Brett, you were actually talking to 2tonChevy who has the same exact boat but with a couple inches more setback and a different bracket. I'm running the old Gil brackets at 24" of setback and turning DAH 26pitch choppers @ 6000rpm spinning out. I'm in the process of swapping my lowers right now to try turning the props in to see what happens. The boat is a "V" pad bottom boat and layed up with AME 4000..so along with my cabin being empty it's pretty light for 28' of length. I'm as high as I can go (without switching to 20" mid sections) so short of trying different props I'm at the end of my "dialing in" the boat...unless I drop my motors down on the Gill brackets...
bbladesprops 04-09-2013 02:53 PM
A 4 blade propeller such as our Blaster would be a great upgrade from the Chopper propellers. These props offer both bow and overall stern lift. They are very fast and are not as compromised by weight.
Let us know if you would be interested in testing these. So far they have been stellar on single and twin OB Checkmates.
Brett
msm 04-10-2013 12:50 AM
I Don't Get It
Brett
How can you lift the bow without pushing down on the stern?
bbladesprops 04-10-2013 11:48 AM
Great question.
I usually tell people the only way to create bow lift is by pushing down on the ster. This is true unless you have a hull that induces its own bow lift to its aerodynamics.
The BBLADES Blaster is a 4 blade propeller with 14.75" of diameter. This in itself creates more stern lift than 3 blade 14.5" chopper. This is just the physics of the propellers. In addition, the Blasters have a aggressive rake angle and specific cupping in specific areas to add in leveraging the transom when positive trim is added. Therefore the props pick up the stern slightly while still being able to add tons of bow lift.
On my 20' padded V bottom these propellers provide more overall lift and trim than any other propeller I've tried or modified and I have tried a trunk load of them.
Brett
speeddr2000 04-10-2013 11:50 AM
Hello,
Brett
+1 on this also makes docking with just the motors a ***** too.
msm 04-10-2013 01:21 PM
Got It
Originally Posted by bbladesprops (Post 3902679)
Great question.
Brett
Thanks for clearing that up, Brett.
JUPITER PULSARE 04-10-2013 02:28 PM
Wish I could round up some of the old Ocean Outboard crew who raced the 2800SX outboards...I'm sure they my remember how they set the boats up in the mid to late 80's!
bbladesprops 04-10-2013 05:20 PM
Labbed Mercury Chopper 1's (14.5" diameter) with the engines deeper than you might think.
With the larger diameters and multiple blades we have today, there are more options.
Brett
JUPITER PULSARE 04-17-2013 10:04 AM
So I ran my boat for the first time last night with the props spinning inward. The boat felt lighter and ran very level as if the stern was being carried higher. I could actually feel the boat on the pad above 65 mph. There was also no mid speed porpoising...at 6000/6200 rpm turning DAH chopper 26's I GPS'd at 70.44 mph with 3/4 tank of gas @ sea level with 80+ degree weather in flat calm water...It was getting too dark to continue making high speed passes...the best I saw spinning outward was 71.11mph so I'm very close in speed either way..the big difference is in the handling..it feels more fun to drive the boat spinning in. You have to drive it like a small V-pad hull and fly it on the pad with nimble corrections..
