| rob vanharten |
05-06-2013 01:22 PM |
Brett bblades I need help with zt280.
I called today for you, but you were busy thought I might get through to you quicker this way :) I have a 99 zt80, with a 700hp procharger motor. But runs very wet, running 77 on gps and just touching the factory rev limiter 5100 rpm's with 1 1.5 ratio xr. Any ways can you add cup to my factory 28p bravo 1 four blade to achieve a lot of bow lift, and by doing so will I be running faster and there for be hitting my rev limiter easier/ more often? So maybe I should start with a 30p, or can actually make my 28 a 29......... I ran a few props over the weekend, the 3 blade mirages would not even get on plane. Prop shaft is 6.5 inches below running surface. I was surprised I couldn't get on plane with a 3 blade.
