29 Nordic MCOB stock 502 high slip
1 Attachment(s)
So I ran on Monday and came up with the below numbers. Seems like a really high slip amount. This is a straight bottom V. The prop is a Mirage 21 3 blade. Being pretty new to boating what would you run on this if it was your boat?
28's pretty high. most of us run 4 blades, some 5 blades.
I noticed you have 1:36 gears. Are you sure? If so I can tell you a switch to 1:50 gears should help you.
If the above numbers are WOT for a 502, they are way low, even with 1:36s. The stock 502 Mags and 496 Mag HO Heats I've set up here can all pull a 26" Bravo 1 4 blade to about 5000 RPM with 1:50s, which is about 65MPH, GPS. I don't know anyone running 3 blades anymore on an sport boat. They won't lock up or carry the bow. Regards, Steve |
Originally Posted by Steve Zuckerman
(Post 3935210)
If the above numbers are WOT for a 502, they are way low, even with 1:36s. The stock 502 Mags and 496 Mag HO Heats I've set up here can all pull a 26" Bravo 1 4 blade to about 5000 RPM with 1:50s, which is about 65MPH, GPS. I don't know anyone running 3 blades anymore on an sport boat. They won't lock up or carry the bow. Regards, Steve I would like to do a 1.5 but will try a 4 blade 19 first. Thanks for the replies gentlemen! |
| All times are GMT -5. The time now is 10:05 PM. |
