-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   1998 27 Fever with 496 Strocker prop help! (https://www.offshoreonly.com/forums/prop-talk/299407-1998-27-fever-496-strocker-prop-help.html)
Enforcer27 07-08-2013 09:04 AM
2 Attachment(s)
Hey Guys, I am turning a 27 Fever with 496 Stroker Dyno'd at 550hp. The prop I have on it now is the 3 blade 23P Mirage. I am getting about 70mph on gps, with rpm's creeping close to 5400.. Max hp is at 4800 according to the dyno sheet so I don't believe there is any reason for this over revving.
Anyway to get closer to 80? I have heard suggestions from 24p 4 blade to 26 Hydro?? Props are $$ just want to make a good close choice before I whip out the bucks..[ATTACH=CONFIG]504008[/ATTACH][ATTACH=CONFIG]504009[/ATTACH]
bbladesprops 07-08-2013 10:18 AM
We have a test propeller program that allows you to test without buying props. We are the only company in the country that I know does this. We can offer some options and you can test those props.
I would be interested in seeing your dyno sheet to determine the best propping rpm as well.
Let us know if we can help.
Brett
Enforcer27 07-08-2013 10:28 AM
Let me know what I need to do for this program. I can email or text you a copy of the dyno sheet however you like. Thanks
Chris~
Brett
Pat McPherson 07-08-2013 02:04 PM
A good bud of mine has a 97 with about the same power running a 26p Bravo 1 with extra cup. 75mph @ 5200rpm
Sadouglas2012 07-08-2013 02:29 PM
The bravo 1 26 pitch prop works for me ,at 5600 rpm runs 80 on GPS with fuel tank full and four people , ZZ502 gm crate engine .
Enforcer27 07-08-2013 03:15 PM
Bravo 1 26P seems like a very big jump for me from a 23P? I would like to see upper 70's to 80's on GPS thought!~
hec2buck 07-08-2013 03:39 PM
Hello,
I can't even guess how many 27 ft. Fountain's we have propped out with both stock, and modified power. With stock power the Quad IV works very well. That was the prop of choice by Fountain until they were taken over by MerCruiser in 2001. With modified power the P-5 X is by far the best solution on your application. Great hole shot, unparallelled mid range speed, and the best top end.
We have a 30 day trial period on our returns and exchanges. Give us a call to review your application in more detail.
Thanks,
Thom
bbladesprops 07-08-2013 04:26 PM
Actually Reggie wanted all Labbed Mercury Bravo 1's on his boats but in 1998 the Mercury Racing bean counters wouldn't allow Dennis and I to give Reggie a additional discount. The result was a upset Reggie and a move to other props to spite us. (True story).
That does not mean the Q4 propeller isn't a great prop. It works well. In some cases under certain set ups it will out perform the Bravo 1 on top end. However, from plane ability to mid range the Bravo 1 is almost always the better choice. As far as top speed, the Bravo 1 is 50/50 the better top speed performer in stock configuration and almost always faster when Labbed.
As I stated before, with our test program, you are not required to purchase a propeller. You simply pay a test fee of $45 to test a prop. Some other companies allow exchanges but not a true "test" program. We have Mercury, Hydromotive, Turbo, and some Hering propellers for testing.
Enforcer 27, call me or Brad or Kaila and we can set you up in the test program. Email the dyno sheet to [email protected]
