Trying to identify my prop ...hydromotive?
Numbers stamped neer the splines are: HC-CL23L-O-IV
Four blade Measures just shy of 15.5" from tip to tip I'm thinking this is a hydromotive intimidator quad IV 15.5x23p If you need more info let me know ill try and post a pic |
You are correct. That is what you have. LH rotation.
Brett |
Ok great
Ok I have a 27 fountain with the 502 mpi and I guess they come with the hydro from the factory and out of the factory the sheet claimed 68mph @5000rpm I was getting 55mph gps speed out of the hydro so I took it off and bought a bravo 1 labbed prop off here and now I am around 60mph @ 46-4700 rpm with the bravo My question is what prop would I be better off with for speed? I'd like to be around 68-70 where most 27 fountains are running |
Both props can work well. Our experience has shown a properly Labbed Bravo 1 to out perform the Q4. This isn't 100% of the time but in the majority of the cases.
Was the 23 Hydro Q4 on the limiter? What pitch is the Bravo 1 you bought and where was it Labbed? I assume it is a 24 pitch. In order to run 68 mph with a Bravo 1 24P, you would need to turn it 5100 at 9% slip. That looks to be a tough option since you are only at 4650 now with 12.5% slip. Let us know and we can help to get you closer to your goal. Brett |
The hydro was at 47-4800 if I remember ...that was in 60 degree weather last season
The bravo is a 24p
The hydro is a 23p that came on the boat from the factory and they claimed 68 mph WOT |
I have your testing form and going to do some testing this weekend on both props
Perfect,
Let's get some back to back accurate numbers and go from there. Brett PS, if either of these props have been touched, even repaired, I need to know. Also, LH props are common on your hull due to listing.................... |
The bravo, I was told it was "labbed" but not positive by who
The hydro looks like it has been touched I could send you some pictures if you want also |
Yes,
Email the photos to [email protected] See if there are any stampings on the barrel or inner hub of the propeller as well. Brett |
| All times are GMT -5. The time now is 12:33 AM. |
