-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   600hp 22' Scarab XR/-1 propping (https://www.offshoreonly.com/forums/prop-talk/302159-600hp-22-scarab-xr-1-propping.html)
CaribouLou 08-28-2013 11:11 AM
I've ran a stock 30 Bravo, and a labbed 28 bravo. Both props around 78 mph the boat really starts moving around. I think I need more bow lift, as I think I'm feeling bow steer. Any opinions?
hec2buck 08-28-2013 03:41 PM
What rpm are you turning both props, and where does your engine make peak dyno horsepower? This will help us figure ouv what is going on.
CaribouLou 08-28-2013 04:32 PM
The 30 about 5k, the 28 about 5200. The motor is still pulling but I'm forced to let off due to general respect for my own life lol.
bbladesprops 08-29-2013 11:04 AM
What rpm do you desire to turn the engine up to? How far are you trimming the drive out at 5-5200?
We will have to consider possible test propellers for you.
Brett
D Harry 09-04-2013 09:46 AM
I have a 525efi on it, with a -2 imco shortie and still didn't find the prop for it :-( plenty of stern lift above 70mph!! Best I ran till now is 78mph with a hydro P5 30 pitch @ 5100 rpm but alot of bow steer,stern lift and china walk that i have to pull back. Then i tried a Bravo but plenty of china walk with a 4 bladed. P5x plenty of slip and very slow accellation. Any idea would help??? But i would like to know if a hydro P5 can be worked on for plenty of more bow lift
CaribouLou 09-04-2013 02:07 PM
Your drive is too short, causing most of your problems. You need to try a 1.5" spacer
bbladesprops 09-04-2013 06:00 PM
Modifying your propeller may become a requirement.
Spacers are options too but I would want to talk to you more about that first.
We have a spacer plate test program too. You can test spacers without having to buy them.
Brett
D Harry 09-06-2013 02:40 AM
I tried the spacers already, and it didn't improve anything. Just for your info the prop shaft is 4" below the pad.
Harry
D Harry 09-14-2013 03:20 AM
BBADWS6 09-14-2013 01:28 PM
Ive got a buddy that has the same boat as you with no drive modifications, its a stock Bravo 1 at stock Xdim.. Hes running less HP than you and turning more RPMs than you and runs 78 on a stock 28B1. He ran low 80s on a mirage 25P but the boat got too squirly. 78 to 80 is all that hull likes before it starts getting squirly, unless you have trim tabs.
