Cig Bullet Propping >
Cig Bullet Propping
Cig Bullet Propping
Old 04-06-2014, 08:23 PM
Default Cig Bullet Propping
I know this has been discussed on some older threads, but I wanted to get some up to date opinions. I have a 1988 Bullet, no notch. It's a heavy boat with a full cabin.
Boat has Bravo drives (old style) , about 550hp a side (not dynoed). Engines are 468ci, 250 blowers, stainless marine exhaust. Right now, I have 27 pitch Mirages and spin 5100rpm. Speed is low 70s.
Looking for better cruise and a little more speed. My thoughts from some research has me thinking 26 pitch Bravo 1 4 blades.
Appreciate thoughts, opinions, and data. Thanks!
Hollowpoint is offline
Old 04-06-2014, 10:52 PM
formula 382 sr-1 is offline
Old 04-07-2014, 01:38 AM
Received 1,821 Likes on 907 Posts
I agree with the 26 Bravo's. They should turn about the same rpms as the 27's you have.
Griff is online now
Old 04-07-2014, 07:37 AM
Biggus's Avatar
+1 , Cruise should be much better.
Biggus is offline
Old 04-07-2014, 08:37 AM
carter38's Avatar
+1 I think you'll be pretty happy with the all arounds gains of a 4 blade.
carter38 is offline
Old 04-07-2014, 09:53 AM
I have some 24 hydromotive 4 blade that you can try, I don;t know how they work on a Bullet and they maybe to small !!!
Old 04-09-2014, 05:38 AM
Maybe Brett from BBlades can give you some insite and he has a test program.!!!
Old 04-09-2014, 09:20 AM
I'd try a revolution 25 four blade. The drives are prop pretty deep on the bullet. I think that prop would work well for you
MILD THUNDER is offline
Old 04-11-2014, 10:55 AM
carter38's Avatar
I've never had any luck with hydros on a bullet from what I've tried. Bravo 4 blades seem to be the ticket.
carter38 is offline
Old 04-11-2014, 11:06 AM
Have you tried a revolution 4 blade ?
