props size - help please
Hello;
We have boat with next datas: - weight 12.000 lb - lenght 30 ft - 2x diesel 275 hp each and 3.300 rpm wot - Arneson 6" drives - drop down with 1,2 reduction What kind of props with what dimensions to put on shafts for best results? bye Saso |
20 pitch prop will take you to 45 mph at 3300 with 15% slip. Diameter is dependent. Start big (16.5"-17" ???) you can always cut it down. You may need a custom propeller to find this size.
HP to weight ratio suggests you should be able to do this pitch. Of course this is without knowing the boats configuration. Brett |
| All times are GMT -5. The time now is 03:30 AM. |
