-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   What prop for 26ft Regal Leisure Cat? with a 250 EFI Mercury (https://www.offshoreonly.com/forums/prop-talk/313953-what-prop-26ft-regal-leisure-cat-250-efi-mercury.html)
Inrecovery 06-18-2014 06:38 AM
Just pu the boat Monday, It has a 23 Mirage , 3 blade Boat shows 3200lbs dry , but Im sure from reading other posts its more like 5k. The boat new shows a 225hp. Im not looking for top speed , was thinking a 4 blade? Anyone have one of these boats, or worked on them. 1993 to 1996 where the production years.
Maritime_Eng 06-18-2014 07:35 AM
I just bought a similar boat. Mine is a 26 bayliner rendezvous 1994 for a party barge. I ran it last weekend for the first time. Because both yours and mine are semi planning hull the prop really wont make much of a difference. I am running a 22 bravo. The older engines like the force engine that were on our boats had small diameter props so either your mirage or a bravo would be an improvement.
bbladesprops 06-18-2014 11:15 AM
A Revolution 4 in the proper pitch is a great option.
We have them for testing if you desire.
Brett
Inrecovery 06-21-2014 06:49 AM
Looks like I need to lower the engine, Boat was from Marco and was set high(shallow water) and lower unit is a 20inch, not 25 like the factory. Cant get on plane with 23, tried a 4 blade 19 on thursday still blowing prop out. Found a set-back plate on BoBs Machine Shop, looks like this will do the trick.
Maritime_Eng 06-21-2014 04:48 PM
Mine was way too high also. Prop would blow out when ever I tried to run full throttle. I lowered the engine 2 inches and runs much better.
