-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   what to expect? Mistress 600 hp....BBlades??? (https://www.offshoreonly.com/forums/prop-talk/314606-what-expect-mistress-600-hp-bblades.html)
Full Force 08-13-2014 06:48 AM
Honestly I am pretty happy with performance so far with only 600 hp I make lots of tq so that is where these speeds come from, Brett thinks there may be a couple more mph there and that would really be impressive for the TRS mistress ...
MILD THUNDER 08-13-2014 07:00 AM
Back when I had my 402 Formula I tried them. There is a local prop shop about 20 min from my house that used to demo props. At that time the boat had 26p labbed maximus props. I could only get around 5000 rpm out of them and my engines really needed more rpm. So I tried a set of stock 25 revolutions. What I immediately noticed was the boat planed easier (less throttle) , less vibration planing too. I don't recall the cruise numbers but, was able to pull them to around 5400 and gained around 4 mph over the labbed 26 maximus that costed over 3k with all the work to them. The boat actually felt better at wot too. Like more on rails. With the maximus it felt kinda loose, like too much stern lift or something
I then tried a set of 27 mirage plus props. Took forever to plane with them. Actually lost top end with them. Best I could get was about 66, where the revolutions got me 72-73. My Formula was weird though. The drives were a bit high for a TRS application. I think the boat came with ssm ii drives and someone put trs on it which would have raised the propshaft a bit.
Anyhow, I was really impressed with the revolution props.
Full Force 08-13-2014 07:14 AM
I will look for some to try if I can, I read in past you liked those on the 402, I am gonna spin drives in this week and see what happens, gonna swap them tomorrow night
Full Force 08-13-2014 07:15 AM
Did you try "worked mirage" or stock? Brett said stock 27's need work to work good... Just going off what he told me
stimleck 08-13-2014 09:52 AM
go on kijiji/craigslist do a deal where you pay in full and get your money back if they dont work, I did it and had good success
Full Force 08-13-2014 10:06 AM
I can "rent" 27 mirage from BBlades I was talking the revolutiins
