-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   mounting hydromotive props on bravo x drives (https://www.offshoreonly.com/forums/prop-talk/315506-mounting-hydromotive-props-bravo-x-drives.html)
c_loud 07-19-2014 06:43 PM
just bought some hydros from a guy and there is a gap between the mount nut and the prop on the shaft. what is needed to eliminate this gap? can i run these without anything? i am thinking not. thanks!
bbladesprops 07-21-2014 03:17 PM
The first thing that goes onto the prop shaft is the forward thrust washer.
Brett
c_loud 07-21-2014 04:30 PM
OK brett, thanks! I never took mine off so it should still be there. There is a brass washer at the base of each drive shaft
