-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop for 272 Baja Islander 502/500hp (https://www.offshoreonly.com/forums/prop-talk/316570-prop-272-baja-islander-502-500hp.html)
sabo 08-19-2014 10:29 AM
31% slip indicates a bad prop or prop breaking loose and not hooking up.
http://pages.suddenlink.net/kmielen/C320Docs/Tach.htm
http://www.amazon.com/Digital-Laser-.../dp/B007KGHD3O
Im sure there are more ways, i just did a quick search.
Baja Rooster 08-19-2014 11:13 AM
That method of checking the tach is pretty interesting. Thanks, Sabo, for your legwork and help.
Baja Rooster 08-19-2014 03:27 PM
Spoke with Brad at BBlades, and he's hooking me up with a Revolution4 21p after I play with some tuning this weekend. I'll let you know how it all works out.
sabo 08-20-2014 12:46 PM
21p? seems like going the wrong direction in pitch, but hopefully motor runs good and you can get some decent numbers to go off, good luck!
My predictions are if motor running good, you'll hit 60 at max rpm.
Baja Rooster 08-20-2014 12:52 PM
21p does seem backwards, but it is a 4 blade vs the current 3 blade. I'd be totally stoked with 60mph. From what I've seen on the internets these open bows tend to lose ~5 mph compared to the cuddly cabin bretheren.
sabo 08-21-2014 06:09 AM
Open bow! didn't realize that, but with the right prop i think you should still run around 65 with 500hp...
just keep in mind, weight makes a big difference, so if you have a full load with 4 people and 3/4 tank fuel your going to run slower
Baja Rooster 08-21-2014 08:21 PM
So I put a dial indicator on the prop blades, and with the first blade set to zero the next blade was .03 out and the next was .05 out. Is this significant?
http://i622.photobucket.com/albums/t...8064663108.jpg
http://i622.photobucket.com/albums/t...67E171B70E.jpg
sabo 08-22-2014 01:24 PM
Prop looks decent to me, i don't think this measurement is relative to the issue, but im no prop expert.
articfriends 08-24-2014 10:28 PM
My 272 ran 62 stock with a 23 mirage plus at 5050 or so *, would hit 63-64 completely empty no fuel, no passengers empty banging rev limiter (502 mag)
Baja Rooster 08-25-2014 12:41 AM
Thanks for the input! Cuddy or open bow?
Yea, I'm getting almost 32% prop slip for some reason. 50mph @ 5k with the same B1 Mirage Plus 23p.
