-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Fountain Fever 32 Prop (https://www.offshoreonly.com/forums/prop-talk/319326-fountain-fever-32-prop.html)
T_traylor1 10-20-2014 04:33 PM
I just recently bought a 99 Fever with twin 502 EFI's, i had it out over the weekend with 3 or 5 people would only run 71-72 on gps, does this seem right? it has Bravo 1 26p props now is there a prop that would maybe give a little more top end, as well as fuel milage (I am aware it will never be good, but a little bit always helps)
onesickpantera 10-20-2014 06:42 PM
From what I have read that is a little low, as it should run 75-77mph. What rpm were you running? Might want to also post in the Fountain section.
T_traylor1 10-20-2014 07:41 PM
Unfortunately I do not know the Rpms, was just kind of thinking today while at work that it seems there should have been a bit more speed but wasn't sure, the original test report from fountain list speed as 79.
