-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   HP vs pitch (https://www.offshoreonly.com/forums/prop-talk/324318-hp-vs-pitch.html)
arttu 03-22-2015 03:59 PM
HP vs pitch
Hello! I´m wondering is there any rough formula to calculate prop pitch vs engine or shaft HP?
I´m going to add 256 blower on my 454mag and wondering how much pitch can add to prop?
Specs now: 350HP max 5100rpm and top speed 65mph with 23"mirage, Bravo 1 1.5:1. I´m happy with current acceleration and would like to keep it about same with blower...
Is it possible to calculate HP per pitch for example 350HP / 23"pitch = 15.21HP per pitch?
If adding 100 HP with blower could it be 450HP / 27"pitch = 16.66HP per pitch?
I undestand steeper prop the more HP needed but is there any way to calculate?:pray:
Griff 03-22-2015 07:06 PM
Plug in some numbers on Bam's site http://www.go-fast.com/boat_speed_predictions.htm
bbladesprops 03-22-2015 07:51 PM
bam/Marc put the Merc calc on his site.
Here is our calculator.
http://bblades.com/propeller-slip-calculator/
Back in the day, we also wrote a equation to determine the potential speed per the HP to weight ratio based on the efficiency of the particular hull. This is different from the slip calculator.
Call us and I'll give you that number and better answers.
Not the best way to calculate without experience but it is a way to estimate............ we basically use 1" of pitch per 100HP gained but,,,, every application is different....every application is unique.
B
kidturbo 03-23-2015 12:20 AM
Both are good tools to come up with the numbers your after. I've found BAM's speed and slip calculators to be pretty freaking close. Especially if you have current engine data, GPS speeds, along with an accurate boat weight. Then just plug in the changes to power and pitch to see what fits.
Pliant 03-23-2015 02:03 PM
Just used Bam's model it came within 1mph...pretty cool app there.
arttu 03-23-2015 02:57 PM
Yep, calculating with those I came up with 26"- 27" pitch.
I´m struggling between props Dia 15 1/8 26p or 14.5 27p. Both 3 blades...
Never had slip issues so would`t like to increase dia. I believe my present mirage is 14 5/8.
I have pretty light hull, small boat (regal medallion 18ft). Weights about 2800lbs. I tried 15 1/8 28p 4-blade last summer WITHOUT blower and the top speed remained same but acceleration was like driving with grandma... also top rpm lowered to 4000. So bad memories of too steep prop.
I´m definately going to run first with present prop and testdrive engine with blower on and see how it sounds.
Trash 03-23-2015 03:17 PM
It depends on where the new motor makes its power and how big the torque curve is as others have mentioned. For example a new motor may have a similar torque curve but makes peak power 800 rpm higher. You actually may not even go up in pitch but simply run the same prop at a higher rpm. Just some food for thought.
SB 03-23-2015 03:18 PM
Edited: Ooops, saw 350hp and small boat and assumed mild small block. My bad.
arttu 03-23-2015 03:31 PM
It revs up to max (5100) with present prop easily so definately need to add some pitch with blower mounted. Just the question is how much :) I believe blower will add about 100hp? 454 mag, Gil offshore alu exhaust, double 600cfm holleys and weiand 256. Sounds reasonable?
Trash 03-24-2015 12:42 AM
Doesn't matter where it currently revs up to, but rather where will the new motor make peak HP. You will need to prop to the new motor. Don't get super focused on pitch alone. You might need blade surface area (bigger 'ears' or more blades) or perhaps additional diameter. Now I'm not saying pitch change won't be required but there are other factors in the prop that may optimize overall performance.
If I were you, I'd start with your current prop and run it with your new motor and get a SOLID BASELINE. Record in 200 or 250 rpm increments from idle to WOT the rpm and GPS (I say again GPS) steady state speeds. Compare your theoretical speed to your actual speed to get a feel for slip and efficiency. Once that is done you will have a much better grasp on which direction to go in prop selection. Now there is a fair chance you may be bouncing off the rev limiter with your current prop and new motor. So be it. At least you have a baseline from which to compare.
I wish you success in your project.
arttu 06-22-2015 02:54 PM
Blower installed and tested :) Yeah there is a "little" bit more power and torque :)
I tried 27p solas L3 and had huge problems lifting boat to planing, slipped horrible at the start. There was enough power to spin it when finally got boat planing but acceleration was impossible so ditching that prop.
With current mirage 23p it`s like drag boat and engine revs about 6000rpm top speed of 69mph. I actually like the acceleration but would like to have little more cruising speed and maybe top end speed, not spin the engine so damn fast.
I`m thinking to go 25p mirage+. What do you guys think would it give more cruising & top speed? It is more cupped than normal mirage, so I´m wondering will it be any faster or should I stick with my 23p?? Or try something else?
BBCLiberator 06-22-2015 04:10 PM
You didn't say you had anything done to the internals of the motor, correct? If not, 6000rpm is asking for some fireworks. I would at least bump it up 2" to a 25 and try that. That will still only bring it down 500rpm or so…which is still to high for a 454 mag. I wouldn't want that engine over 5250rpm….which honestly is pushing it.
Good Luck!
arttu 06-23-2015 10:37 AM
^^exactly... If spinning same engine rpm, will mirage+ 25p be faster than normal mirage 23p??
himrod67 06-23-2015 11:47 AM
Yes
kidturbo 06-23-2015 12:39 PM
Now is where using that prop calculator comes back into play to compare speed vs RPM again. You know it will spin 6000, so I'd jump up 2 or 3 in pitch and possibly find one in a 4 blade to try. Personal preference, but I like the hooked up feel of more blades even if it cost me a couple mph.
BBCLiberator 06-23-2015 03:35 PM
Sounds like we shoul explain pitch. Think pitch as inches. Every time the prop turns one full revolution, it will move that amount in inches if it were traveling through something solid. We know this isn't true completely and that is why you have some "slip". The higher the pitch the more it moves your boat per revolution, and the faster you go at the same engine RPM.
arttu 06-23-2015 04:22 PM
Don`t worry I´m not that dumb as I look :) :) I Ment that there`s a difference in cupping between mirage and mirage+ props if understood correctly, so was wondering if this cupping reduce speed? Anyhow I ordered just cheap mirage+ 25p and hope that my rubex hub will fit in it. Prop had a square hub hole in pic... Let`s see how it works!
bbladesprops 06-24-2015 04:19 PM
The old Mirage was thinner with less cup. It was faster on efficient hulls.
The Mirage + has more cup and can be faster on less efficient hulls.
Brett
arttu 07-11-2015 07:41 AM
Hello! Now I have tried 25p mirage (non-plus).. It was ok but "blows out" just after planning. Need to reduce gas, it gets grip and then we go :) Top end was 72 mph @ 5500 rpm. So seems that my limit with 3-blades ends at 23p...
Now I think I´ll start testing 4-blades. I think I can bump pitch to 26. I found two props in Sweden. Bravo 1 26p and Turbo 2+2 26p. Bravo 1 is dia 15.25 and Turbo 2+2 dia says 14.25..
I´m wondering how much will lose "agression" of engine if bumping dia from present 14.5 to 15.25??? Or if reducing to 14.25 is there risk of blow out and slipping again? What do you think?
bbladesprops 07-13-2015 12:29 PM
The Bravo 1 is only 15" diameter. The marketing of the propeller suggests 15.25". The only 15.25" Bravo 1's are the 34 and 36.
Try them and see. Testing is the official answer to how they perform. Load the boat like you would in a normal boating day.
Brett
