formula 271 sr1
hello everyone i have a 1994 271 with a stock 502. right now it has a 24p bravo 1 wot is 4200 rpms do i need to go up or down in pitch? ive heard with a 22p i cane see high 60's on this hull is this in reason?
Down in pitch equals increase in rpms
I would think your 502 should be able to spin that prop faster though... |
when i bought the boat it had a 21 mirage on it.
That is for sure too much pitch. A 22 wil probably be perfect.. You will not see 60 though. 58-59 tops.
I would think a 21 would be about right, maybe as low as a 20. 502's like to rev about 200-400rpm's higher than the 454's, they like the 5000-5200 range for the Gen V's depending on the particular model (newer MPI's were 5000max, 4600-5000rpm range). What was the stock prop on the boat?
My boat had a 20" Raker stock and would turn about 5200 rpm at about 62mph. Plug your information below. Prop slip of 10-12% is a good place to start as a guess. http://www.rbbi.com/folders/prop/propcalc.htm And no way you are seeing upper 60's unless that thing pretty built. twin 454's see mid-sixties, a friend who has twin 350/320's sees about 63 stock. I would agree, mid-to-upper 50's. |
| All times are GMT -5. The time now is 02:08 PM. |
