Boating Season might be over... Prop damage...
3 Attachment(s)
So, I noticed a slight vibration at slow speeds and low rpms with the starboard motor a couple weeks back. I normally check the leading edge of my props and there are a few minor little nicks so I know that it should be addressed. Got back from the Buffalo Run yesterday and tucked the boat away. Checked on it today and saw two small tears in the trailing edge of my starboard prop.... Not sure if it can be repaired or if I will need a new prop...
I would contact BBlades on here or call their shop. :drink:
call Brett at BBlades they can fix it
I'm gonna give them a call tomorrow. Thanks for the input guys. The consensus in the prop section is that the prop is toast. I'm sure it has all 520 plus hours on it for that motor...
I've seen props looking far worse than that get repaired and last a lifetime!
Easy repair for the pros IMO. |
Shogren has some used ones at a good price.
I would call Murphy's Propeller in Virginia Beach, VA. I have had them blue print numerous props, and their machine shop can fix almost anything, not just hot-rod props, but all props, and they are good at what they do.
http://www.murphyspropellers.com/ |
That can be fixed! I have had props that look that bad fixed and they are still on my boat! If you have questions feel free to pm me and I will get you the info you need. Rob
Season over for a prop ding? Common now .
Originally Posted by RollWithIt
(Post 4340879)
| All times are GMT -5. The time now is 04:25 AM. |
