-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop advice 25 warlock (https://www.offshoreonly.com/forums/prop-talk/330734-prop-advice-25-warlock.html)
actionmarineguy 09-14-2015 07:37 AM
Just finished up a 1990 25' warlock cat 525 sc engine bravo 1 with 1.5 ratio. Not sure of weight, Tried a 26p 4 blade bravo 1, largest prop I have. easily got up to 5500 more to go, Anyone have advice on what may work best? any input would be helpful.
sabo 09-15-2015 11:51 AM
Probably try a 30p next
actionmarineguy 09-16-2015 09:35 AM
Thanks, Just found a 27 mirage plus 3 blade to try. probably not enough pitch, Never had a single engine cat before anyone know what would work better 3 or 4 blade?
JRider 09-19-2015 12:09 PM
I have never seen anyone run a 3 blade on a cat. Typically they have natural bow lift so a transom lifting prop can be benificial. A 3 blade is not conducive to stern lift. Hydromotive Q4 might be a good choice. My 28' profile loved stern lift, I ran 5 blades on it to take advantage of that.
actionmarineguy 09-21-2015 08:00 AM
Thanks for the input, did try the 27 three blade. more speed and still needs more prop, Boat did porpoise a little at speed, not sure why, trim made no diffrance Will see if i can find a 4 blade to try.
sabo 09-21-2015 08:13 AM
3 blades do the same thing on v bottom hulls, im guessing due to increased bow lift?
What were the numbers with the 26 and 27, speed and rpm?
actionmarineguy 09-22-2015 08:07 AM
26 4 blade bravo 1 5500rpm 72-74 mph 27 3 blade bravo 1 plus 5500 80 mph pushed the throttle to 6000 couple of seconds did not note top speed it would go more but stopped. This was on gps. 30 p prop most likely a good call to try don't have one to try yet.
Thanks for the advice.
Baja170 09-27-2015 02:21 PM
I am currently running Between a Signature SL4 30P worked by Hole Shot Propellers cut barrel, vents and a 30P Bravo 1 BBLades Labbed, thinned blades, added a little cup and trim barrel on my Cougar MTR with good results to about 85MPH. 500EFI and Bravo 1. Highest RPM I have seen is 5300. I also have a new Bravo 1 32P I am thinking about sending to BBlades to have them do the same things they did to the 30P when they are slower in the winter. If you had warmer weather I would let you try one of them and see if it helps. LOTS better than stock Bravo 1 30P on both of these props. The thinned blades of the BBlades worked Bravo 1 are awesome from low mid to top mid and give bite from about 20MPH to 70 very well. The SL4 gives similar results and I for how cheap it was, about 1/3 the cost of the BBlades worked Bravo 1 I really like it.
Griff 09-28-2015 01:16 AM
I'm guessing the 525SC does not have the stock ignition/rev limiter 5350rpms????
BTW, a 26 Bravo spins about the same rpm as a 27 Mirage. 2" of pitch change on the same make prop is about 400rpms.
I would try 28 and 30 Bravo props.
actionmarineguy 09-28-2015 08:11 AM
Not stock ignition rev limit at 6000 for now Engine has all the good stuff 6000 no prob but want to be at 5500 when done
Had a few cats and found they don't play by the prop rules for rpm and speed.
Still looking for props to try Could use another friend in the upper NJ lower NY area:)
Baja170 09-28-2015 09:52 AM
If you want to pay for shipping both ways and buy the prop if you mess it up, I can priority you a prop to try. It should be a big improvement over what you have now. I don't want to sell it but it will give you a very good idea what a worked 30P can do for you. I am running MSD ignition with the rev limit chip at 5600 right now. Just don't want to blow my B1 drive. I agree with the prop rules. Everything recommended to me besides what the prop shops have done has not worked on my boat at all.
actionmarineguy 10-01-2015 09:08 AM
Baja 170
What a generous offer, Met many nice members here! I am winding down the season here and may not be able to get in the water again til spring, if i don't find anything by spring may take you up if offer is still good. If you are ever in NY look me up Guy
Baja170 10-01-2015 09:12 AM
I am sure I will still have it. I alternate between it and the BBlades worked 30P Bravo 1. I get to NY sometimes, I have in-laws in NJ, CT and MA. When you get your boat back out, PM me and we can work out the details. It works a lot better than a standard Bravo 1 30P for sure.
