| phughes69 |
10-02-2015 04:47 PM |
prop rotational play with Bravo 1's?
I just got a deal on some new props to try on the Scarab. I had old kiekhaefer 3 blade cleavers (think Miami Vice era props) solid hubs. The new ones are Bravo 1's I got the correct heavy duty stainless hub inserts with the props that sit below the thrust washer face about 3/16". I took the hubs out and made sure I had all the snubber strips in place and greased everything up. If I hold the prop shaft still, I can rotate the prop about 3/8" back and forth. It is not rattling around. I figure I would get a little rotational play between the splines of the shaft- to the castle insert- to the hub insert- to the prop, but I want to make sure this is normal.
