-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop Help 27 Ultra Shadow MCOB (https://www.offshoreonly.com/forums/prop-talk/333059-prop-help-27-ultra-shadow-mcob.html)
JRider 01-28-2016 10:51 AM
2 Attachment(s)
Originally Posted by bbladesprops (Post 4391386)
I'm not familiar with the drive plate product.
What I can tell you is planning without additional drive additions is the best option. Added units can create drag and deter speed and boat attitude. Best case is correct X dimension and propeller selection as well as CG adjustments and you will reap the best performance results.
Brett
Brett
It is not a whale tale or aftermarket bolt on garbage. I is an imco upper cav plate extension and it is (in a lot of cases) necessary to plane off with a shorty. The lower cav plate is non existent with a shorty.
[ATTACH=CONFIG]550204[/ATTACH]
[ATTACH=CONFIG]550205[/ATTACH]
bbladesprops 01-28-2016 04:12 PM
Got it. Thought he was talking about the cheap stuff.
When we developed the Shorty Sportmaster at Merc Racing we also created a similar cav plate. We called it a splash plate. It cam standard and was removable as well. And yes, they can definitely help with planning. Just need to be sure your X dimension allows it to be dry when running.
Brett
