-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Mercury max5 prop (https://www.offshoreonly.com/forums/prop-talk/337562-mercury-max5-prop.html)
T-Mone 05-21-2016 05:56 AM
Mercury max5 prop
Has anyone tried on a sterndrive single?
T-Mone 05-23-2016 05:43 AM
BBlades??
bbladesprops 06-01-2016 05:40 PM
This is a cut down Maximus to 15" diameter. It has a reduced blade area designed for lightweight hulls running big OB's.
Specifically the X-Cat series boats with 400's in Europe.
Brett
drejustice 06-07-2016 07:13 AM
DCB has tried some on our DCB with 400s. Feedback to me, Hooked up nice and felt great at all speeds. Still need to try some various pitch/size and tweaking to do and definitely missing some performance #s(6-8 mph) vs the Merc Cleavers...but they aren't 10K like the cleavers are.
bbladesprops 06-07-2016 12:20 PM
One issue this prop is having is the high rake angle creates bow lift.
With the 400R's on the back, less bow lift is needed.
Brett
Toffen 12-25-2016 06:41 AM
Hi!
How is the bow lift and the possibility to run high compared to REV4, 4bl Turbo TXP and 4bl Blaster?
I have bought a 400R and need to run the gearcase much higher than the 350 sci HD version.
Cheeers! Toffen
bbladesprops 12-27-2016 01:55 PM
There is bow lift in these props due to rake and heavy OB's on the back with CG rearward hulls. If you require extra bow lift/stern leverage from your prop, this might not be a good option. For boats with some natural bow lift it will be fine.
Brett
abones 12-27-2016 02:39 PM
Brett
What is the rake on these? is it more then the Bravos?
Toffen 12-27-2016 03:57 PM
Brett
Hi Brett :)
Thanks!
Hayabusa is running a Checkmate 2400 BRX with a 400R. The best results for him has been with a Blaster 25 running 83,5 mph. I am not sure if I can compare my Phantom 25 with his 2400 BRX. My best speed with a Verado 350 Sci has been 81 mph +/- at 6,550 rpms with a REV4 25 which is shortened 30 mm and cupped. However it do not like so much to be run high.
If I should test out a Blaster should I try 26 inch prop?
Happy New Year!
Cheeers, Toffen
bbladesprops 12-29-2016 12:59 PM
The Maximus props are advertised/marketed at 30 degrees. However, with the decrease in diameter and with the slight deviations advertising can have, we would need to actually MRI the Max 5 to know the truth.
So, yes there is higher rake in the Max than the B! but the overall geometry of the B1 is more conducive to bow lift.
Brett
