Decreasing prop slip on 31/32 active thunder
I have a 93' 31 active thunder
5400 rpm 1.5 gear 24 pitch Bravo's 67.5 GPS @17% slip. Tried multiple trim positions kinda found the sweet spot I think. To reduce slip are my only options to step up to 5 blades?. Any advice is appreciated |
Originally Posted by mountainmadness
(Post 4482816)
5400 rpm 1.5 gear 24 pitch Bravo's 67.5 GPS @17% slip. Tried multiple trim positions kinda found the sweet spot I think. To reduce slip are my only options to step up to 5 blades?. Any advice is appreciated If the props are tired or you are over trimming the slip will go up too. Adjusting or face lifting the props will help. Let us know if you wish to do that. Brett |
| All times are GMT -5. The time now is 12:33 PM. |
