-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Boat wont plain out please help (https://www.offshoreonly.com/forums/prop-talk/343029-boat-wont-plain-out-please-help.html)
Sydwayz 12-02-2016 07:47 AM
Just heard back from one of them: 26P Bravo1 4-blades.
It sounds like regardless of what was stamped on the original props (could have been 28s turned down to 26 or so).
...that you need to get a set of known 26P Bravo1 4-blades.
Those props may have been a set that goes with the boat when they wanted to pull a top speed run, and work when the boat has a light load, fuel, passengers, gear, etc. etc. There is a technique the race boat folks use with tall top end props, which involves letting the boat start to pitch the nose up, and waiting until it starts to blow out...
...then yank the throttles back, and let the wake push the boat up on plane; while you throttle up through the wall of water hitting the back of the boat. It's not something you want to do everyday/every time; and it's tricky to master.
Cignificant 12-02-2016 07:54 AM
I have an 03' 33ZX with 496HOs. The boat came with 26s, but I don't know if they were ever "touched". They had some initials stamped on them, so I think they were. Never had a problem getting on plane, but cruise speed sucked - 3500rpm maybe 42mph. I bought new 28s from Merc (unlabbed). Boat gets on plane the same, cruise up by 10mph (low 50s at 3500), and I only lost about 1-2 mph top end (little over 70, depending on day and fuel). Hope this helps...
1989mach1 12-02-2016 08:37 AM
Originally Posted by frickstyle (Post 4506100)
Ron, Lake isn't frozen yet, get out there. Put your props on and try. Measure the diameter and compare to yours. Also, why don't you just call and ask the previous owner, see if he switched them out?
Donnie sead he was going to give them a call but in my eyes I don't think they will say ya I took the good props off and put some garbage ones on....lol just my thought process
Originally Posted by Sydwayz (Post 4506104)
I've got two buddies with 33ZXs and 496HOs.
I'll check with them and find out what their normal props are.
Cool thanks
Sydwayz 12-02-2016 08:38 AM
Originally Posted by 1989mach1 (Post 4506137)
Cool thanks
See the info "Cignificant" posted above. He is one of the two I mentioned. The other one runs 26s.
frickstyle 12-02-2016 08:58 AM
Ron, shouldn't he be running 26s with the smaller motors, compared to yours with the 500s? I guess it should still plane with the 28s..... Just switch your props, then you know what you have.
SB 12-02-2016 08:58 AM
Originally Posted by 1989mach1 (Post 4505806)
We drop it in the water and the boat just stands up and spins not wanting to get on plain. I looks at the props aND noticed that the blades where really thined down. Could over worked props that where not done for this boat cause this.
Yup. Chances are you are correct.
1989mach1 12-02-2016 09:28 AM
Yes I seen that. So it came with 26s and can run with stock 28s so if in deed the 28s that he has have been labed for a particular situation / boat that could definitely throw things way out of whack. Thanks for all the help.
1989mach1 12-02-2016 09:42 AM
That's the plan for now and would try it now if it wasn't winterized and tucked away in the back of a building next to mine. Spring can't get here soon enough. I just want to get all of the kinks worked out for him so he can be happy about his new boat. He had all new bellows gimbal bearings and pins done. So hopefully he will be good to go
Sydwayz 12-02-2016 09:50 AM
Sounds like it wouldn't be a bad investment for you to both go in on a set of 26P B1 props. They may turn out to be ideal on his boat, or the perfect set of backup/spares for both of you if you guys boat together; especially if you make long runs together. There was a smokin' deal on a set of 26s here a week or so ago, sold immediately. Keep your eyes peeled, as this would not be money wasted.
