BBLADES Winter Special! >
Old 02-10-2017 | 03:41 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Originally Posted by IGetWet
That's good to hear. With the scx lower I will most likely be running, I'd like to get as much of it as possible out of the water. If things don't work out at 2.25" below I could drop it down to 4.25" where I was able to get 6-8% slip with a 26p LH bravo 1 on a standard dwp lower (behind the 496ho) last season.
So then I just need a starting point. I have a 28 bravo 1 labbed by you guys, will that be enough pitch and blades going up to 2.25"? I would like to be around 5600rpm with this motor. I was at 4650+/- with the LH 26 B1 and the 496ho 4.25" below the bottom. Thanks
May not be enough pitch. You'll have to let us know what you determine.
We have a new larger diameter 4 blade we just released. It is called the 4-SPEED. It could be the ticket with your higher X dimension.
Brett.
[email protected]
bbladesprops is offline
Originally Posted by VoodooRob
Brett, Shipping out to you tomorrow pair of 32 Maximus, paperwork included and filled out on your website today.
Thanks Rob.
We'll look for them.
Brett
[email protected]
Old 02-10-2017 | 04:38 PM
Brett.
I saw that, sounds like a killer. I'll be giving you a call come spring. Thanks for the help.
IGetWet is offline
Old 02-23-2017 | 04:21 PM
There is still time to get in on the winter special. Get your propellers to BBLADES before the end of the month to save.
Let our team with 90 years of combined experience service your propellers the correct way.
We also off unrivaled personal consulting you just don't get from other prop shops.
[email protected]
Old 03-07-2017 | 11:32 AM
Dam It
Forgot to send them out before I left the country for the last two week of February. Whats the non special price to clean up my LH RH 4 blade hydromotives?
dubaudi is offline
Old 03-07-2017 | 12:03 PM
It is really tough to quote a price without seeing the props.
It could be $50 or $300. You could send me a photo at [email protected]
and I can give you a accurate estimate through email.
Thank you,
Brett
[email protected]
