-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   4 Blade #6 speedmaster props, what rake? (https://www.offshoreonly.com/forums/prop-talk/344074-4-blade-6-speedmaster-props-what-rake.html)
JRider 01-20-2017 10:19 AM
What rake/s were 4 blade #6 speedmaster props available in?
Scooter 01-21-2017 05:42 PM
15-18-21 rake -The higher the rake more bow lift will occur. Just Guessing LOL
ICDEDPPL 01-22-2017 09:54 AM
I believe majority were 15*
JRider 01-22-2017 02:16 PM
I know the 5 blades come in those rakes, I want 4 blades with higher than 15* rake. Like 18 possibly
27daytona 01-22-2017 02:30 PM
Did you get any test time with your DCB? What is the boats attitude with your current set of props?
JRider 01-22-2017 06:53 PM
I came to the conclusion that it needs bow lift, 4 blades worked better than the 5 blades I tried running. The 5 blades were 15 or 16* with some cup at the tip. They only worked in rough water. The four blades that came on the boat worked better. I'm having thoughts of cutting the sub boxes out of the bow and moving the batteries. It bow steers when not aired out, needs some weight loss for sure
bbladesprops 01-22-2017 07:04 PM
We marketed and sold the 4 blades at 15 degrees.
However, we had consistent blade droop due to to wax maintenance that ultimately made the actual rake about 14.5 degrees.
We do get some 4 blade "long hubs" in our CR program. Call us and we can check inventory for you.
Brett
Brett
