-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Best Prop For IMCO SCX (https://www.offshoreonly.com/forums/prop-talk/348191-best-prop-imco-scx.html)
ken728 07-06-2017 10:42 AM
Hope everyone is having a good boating season! It's been awhile since I've been on any forum so if there is a tread on this I apologize.
I have an eliminator 25 Daytona newer bottom with 1000 hp 565 BBC blower motor with a full IMCO SCX,blueprinted -2 1400 lower, it is one of the first 1400 lowers blueprinted from IMCO . Currently I'm runnig a labbed mercury Maximus 33 pitch, I did try a few different props originally and this seemed to work the best . When I built this power and drive package I did it all at once so I have nothing to compare it to.Now that this lower has been out awhile I'm wondering if anyone has had great success with this lower on a boat similar to mine ? I am happy with the boat but the slip numbers are pretty high, in the low 20s.I'm gonna double check my x dimension on the boat. Currently I have no stand off box, and have been told they don't work good on 25 Daytonas.
bbladesprops 07-06-2017 11:18 AM
The Maximus propeller is the best option today when running Bravo style props. However, Lab recipes can be adjusted to improve boat attitude and performance.
I'd love to hear actual performance numbers before and after blueprinting a SCX without changing anything else in or on the boat.
We blueprint gear cases as well.
Brett
ken728 07-06-2017 12:05 PM
Last time I ran it the boat did 113-114 at 6100 it is a 1:35 gear set. And I do believe the lower was blueprinted from imco I'll have to double check that.
bbladesprops 07-06-2017 12:17 PM
The 33 is made from a 34. So, your slip is over 20%.
SCX cases can have high slip numbers. Depth on this case becomes tricky.
Brett
ken728 07-06-2017 12:27 PM
If I remember right someone once told me 34 pitch props don't work well ? Or is that just bravo 4 blades 34 pitch ? The boat does work good id just like to get that slip number down. I can always go down in prop height but up I'd have to get a stand off box which I'm wondering would if it would help my boat or hurt it? I know it would change everything ,CG ,X ect , I was hoping by now someone with a similar boat has had success with achieving lower slip number on a full imco scx on a single engine cat 24-27 foot
ken728 07-06-2017 12:31 PM
Ok I was wrong its 15 1/4" x 32 pitch
Tinkerer 07-06-2017 09:02 PM
What is your prop shaft height in relation to the lowest point on the back of the boat? Not the pod in front of the prop.
It sounds to me like you are dragging the drive through the water.
I have a 26 Daytona with a standard Imco -3 lower, 1:36 ratio, with the propshaft at 2 inches up from the lowest point. I am running a stock 28 Bravo 4 blade at 6100 at 112 MPH. I do have a neutral IMCO box.
My slip numbers are below 8%
ken728 07-08-2017 05:47 PM
Yea from the lowest point of the boat, (the sponsons) my prop shaft is even with the bottom of them. That being said there's no easy way to go up except a stand off box
Tinkerer 07-08-2017 08:42 PM
Your too deep. You need to go up another two inches and put a box on it.
Your draging the bullet through the water. That drive needs to have the water hitting the bottom of the bullet only. That and run a big prop.
You are also probably having a LOT of transom lift. I bet you have to trim up a few numbers from neutral trim setting.
At top speed my trim setting is only about one number above neutral trim.
Ult680 07-26-2017 12:32 PM
I've combated the same issues on a 25 Daytona with a SCX 4. The Lower scx cases are very large and need to be run very high with large props. Just short of adding a positive extension box your kinda stuck. I gutted mine and went to 3" raised box and #6 props. Very costly to only pickup a few mph.
IGetWet 11-11-2017 12:12 PM
I agree with everyone's advice of needing to run these drives high. My application is very different than a Daytona (25 outlaw) but I'm dealing with the "scx blues". I believe my drive is way too deep, 2.25" bellow the pad on a 12" box, so after the notch it's probably closer to 5.5" if we're using the 1" of water rise per 12" of set back. So being that deep I should have better slip numbers but I'm still at 24ish% with a labbed bravo 1 and over 15% with a stock diameter Maximus. I think even with it that deep the difference of lower torpedo diameter vs prop hub creates a big air pocket creating slip.
So long story short the best prop for the scx gear cases are a dig diameter cleaver with the bottom of the case running right at the surface of the water. A new transom may be in my future if I'm going to see my project through... :hitfan:
