I have been wanting to try a pair of bblades 4speeds I here they pull great numbers
I was going to this summer but ended up getting imco lowers so need to see what my numbers are going to be now.
Originally Posted by Chinewalk
(Post 4603962)
Any recommendations on another prop to pick up some rpm and speed? I feel it has a little more.
With one less blade, you should pick up some rpms and maybe speed. Your slip % might just go up though. |
Chinewalk
Griff is right about the 26 bravo 1''s. They should carry the bow a little better and loosen her up a bit which may get you some rpm's and a couple miles per hour. They won't get you on plane like the 5 blades but your drives look pretty deep so I don't think you will have any trouble. Are you turning your props in or out on that boat now? Also if I remember those motors were built with blowers and then went to NA, i'm thinking low compression and you may just be running out of power as well. Your boat looks beautiful and mid 70s' ain't bad especially when your out running in some big water. Have fun with her and I hope to see you on the water this spring. |
Testing our 4-SPEEDS is a great option.
Brett |
Originally Posted by bbladesprops
(Post 4604327)
Brett |
Originally Posted by T-Mone
(Post 4604166)
Chinewalk
(Post 4604327)
Brett Brett PS We have modified the the test program. Test fees charged for testing BBLADES branded propellers apply toward purchase of the BBLADES castings. |
(Post 4617743)
Yes, just give us a call and we will arrange the shipping at your desired timeframe.
| All times are GMT -5. The time now is 08:54 PM. |
