Prop trade?
Anyone got a 28-30p RH they may wanna trade for a 34p bravo? https://cimg4.ibsrv.net/gimg/www.off...0654e9c39.jpeg |
Sounds interesting, I have a Bravo 1 28P RH that's been labbed by BBlades. I run a Velocity 280 and the lab work killed the prop for my boat, too much stern lift. Is your prop stock?
Yes it’s all stock. In really good condition, No knicks! |
Originally Posted by ThisIsLivin
(Post 4667400)
Let's adjust the recipe. Simple. There shouldn't have been a stern lift change with a standard Lab. The geometry of the propeller would be the same. We can build quite a bit of bow lift into the Bravo 1 family. The prop in the picture above looks to have a satin not stock high polish finish as well as some potential cup removed. However, photos can be deceiving. Brett |
The prop in the photo is stock as stated. My prop was labbed with some pitch added which changed the geometry so much it's now unusable on a Velocity hull. The chine walk becomes almost violent at only 65 with even the slightest amount of trim. I used to run 85 before it started.
