-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop help!!! (https://www.offshoreonly.com/forums/prop-talk/361568-prop-help.html)
ccrder1 07-03-2019 10:20 AM
Originally Posted by Knot 4 Me (Post 4694891)
OK, so an '05 should be a full single-step hull, not just the ventilated chine. I think it may also have a small notch at the transom? Cannot remember. Anyways, so you have the trim tucked somewhat at 72 MPH @ 5,200 RPM whereas when you trim it out (but not blowing out the prop, correct?) you are hard on the rev limiter at 74 MPH @ 5,500 - 5,550 RPM? Sounds to me like you can easily pull a 28p Bravo I and go from there.
Yes full step hull with the pad at the transom... A 28P was exactly what I was thinking.
ccrder1 07-03-2019 10:22 AM
Originally Posted by F-2 Speedy (Post 4694894)
is there a drive shower pickup in the cavi plate ?
I do have a shower... And I did cut the pick up tube as short as I could when I installed it.... That one baffled me on the last boat I had!
If the pick up tube is installed too deep it will mess with the prop in a bad way.
