-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop Recommendations 29' Profile Twins with Notched Transom (https://www.offshoreonly.com/forums/prop-talk/364639-prop-recommendations-29-profile-twins-notched-transom.html)
MooresWarlock 01-16-2020 08:31 PM
29' Profile running Bravo one drive 1:50 gears looking for prop recommendations It has twin 7.4L L29 mpi motors, notched transom I'd like good out of the hole and decent 60'sh top end Thinking Bravo one 22p four blades???
Griff 01-17-2020 01:04 AM
I would think it will run upper 60's easily. I would start with 24" Bravo 1 props or maybe even 26's depending on what rpm you want to spin the engines.
MooresWarlock 01-17-2020 11:14 AM
Thanks for the info Griff - it's a pretty heavy boat and the motors are only 310hp so not sure I can spin the 26's. Next question - setting up the drive rotations - Rotating Outward or Inward?
https://cimg4.ibsrv.net/gimg/www.off...eb9d8c3ef9.jpg
Griff 01-17-2020 01:12 PM
Spin them out
Being 310hp, you are only going to spin them up to about 4600 rpms so 26's may work fine.
hogie roll 01-17-2020 06:15 PM
Originally Posted by Griff (Post 4722140)
Spin them out
Why out?
MooresWarlock 01-18-2020 09:52 AM
Copy that Thx for the update Griff👍🇱🇷
Griff 01-18-2020 12:38 PM
Originally Posted by hogie roll (Post 4722168)
Why out?
Because a 29' V bottom with twin BBC's wont need the added bow lift that spinning inward would create.
bbladesprops 01-29-2020 10:21 AM
Why out?
Once you are ready to test, we can help you with test propellers. We have some BBLADES branded props we can supply you to test as well.
You can easily test inward and outward rotations.
Brett
MooresWarlock 01-29-2020 02:54 PM
Thanks!
Thanks for the update Brett! I'll definitely keep you posted! Quick question - on the Bravo One 4-blade props - I see some with ventilation holes (approx 3/4" - 1" diameter) on the diffuser - better 'out-of-the-hole' performance??
Griff 01-30-2020 01:42 AM
I highly doubt you would need or even see any benefit from props with ventilation holes.
