Help with prop to Chris Craft 260 Stinger >
Old 07-03-2020 | 01:07 PM
  #41
Some news:
I towed the boat up yesterday.
Today I messured the prop shaft height and it is about 1,77 ” below the V-bottom...
pretty high I think.. I only have a 0,5 ” spacer to put on and test with....
What your thoughts?
JohanSweden is offline
Old 07-03-2020 | 08:28 PM
  #42
Yes, it is high for a non stepped hull. You should see improvements with the .5” spacer, but you probably need to go further.
badluck is offline
Old 07-04-2020 | 03:45 AM
  #43
I have think about to trade the Sportmaster to a original bravo One or something else that is lower than my -2” Sportmaster..
that Will make it go lower than with the .5” spacer I think?
Old 07-04-2020 | 07:39 AM
  #44
i think stock bravo would be easy and great solution, that would put your shaft 3.77" below and i quess you would be fine even with 3 blade props. Have heard that below 70mph there may not be any benefits with sportmaster and it is possible that it slows you down a bit.
JaniH is offline
Old 07-04-2020 | 07:41 AM
  #45
Exactly, it will be better I think.
I wonder how much I can get for the Sportmaster.
Old 07-05-2020 | 12:55 PM
  #46
it looks like the propp have been labbed
Old 07-05-2020 | 02:38 PM
  #47
looks like the cupping is reduced from tip of the blade, it also looks that diameter of the prop is cut down, hard to say. stock untouched bravo would be worth to try. My stock bravo 22" is hair over 15" diameter and stock 24" is hair under 15". Dont know what diameter of the 26" should be. Try measure the diameter.
JaniH is offline
Old 07-06-2020 | 10:05 AM
  #48
My Bravo 26p is hair over 15” in diameter.
here is a picture of the water pickup. Measure in european millimeter
Old 07-06-2020 | 11:23 AM
  #49
resurrected's Avatar
Can do some trimming on that
resurrected is offline
Old 07-06-2020 | 11:40 AM
  #50
I got the spacer installed today.
So now it is 2,3” heigh
before it was 1,7”
