Help with prop to Chris Craft 260 Stinger >
Old 07-08-2020 | 08:58 AM
  #61
Ratio 1.3:
3/4= 0.75
1/0.75= 1.3
Ratio 1.5:
1/1,5 = 0.6 = 3/5
plavutka is offline
Old 07-08-2020 | 12:22 PM
  #62
Spinning the engine over twice is actually 1 rpm. If you do that and is it exactly 1.5 that is your ratio
Griff is offline
Old 07-08-2020 | 12:52 PM
  #63
Aha okey, so it isnt 1,35:1?
is it 1,5:1?
JohanSweden is offline
Old 07-09-2020 | 01:05 AM
  #64
With a single rotation of the engine, it is next to impossible to tell the difference. You need to mark the prop barrel at exactly 12 o'clock, rotate the engine 2 full revolutions and the mark should be at exactly 6 o'clock if it a 1.50. If the mark is at 4:30 ish, its a 1.36. You should do this with the spark plugs removed to make turning the engine over easier.
Griff is offline
Old 07-09-2020 | 01:46 AM
  #65
Thank you, I will test that.
The sparkplugs is already removed
Old 07-10-2020 | 01:55 AM
  #66
I did 2 full revolutions on the engine with the propp exactly at 12 o’clock.
ended up like this.. not at 6 o’clock.
more like 4 o’clock..
Old 07-10-2020 | 12:01 PM
  #67
That would indicate that it is a 1.36 ratio.
Griff is offline
Old 07-10-2020 | 12:14 PM
  #68
Thank you for the help.
and that is telling me that my theoretical propp slip is about 39,17%
Old 07-10-2020 | 11:13 PM
  #69
Its a heavy older V bottom. The prop needs to go deeper
Griff is offline
Old 07-11-2020 | 01:13 AM
  #70
Okey, thank you for your help!
The funny thing is that some people here in Sweden, when I show them pictures and they look at my prop shaft height they say it looks fine.
That it should be no problem with the drive that high.. Even if I tell them its a non step heavy V-hull.
They say that I should look at my propeller instead and fix it because that could be the problem.. but maybe they dont really know what they talking about..?
So its really confusing
