1984 formula 242ls with twin 350 mags alpha drives 1.50 ratio >
Old 07-09-2021, 12:35 PM
Default 1984 formula 242ls with twin 350 mags alpha drives 1.50 ratio
Turbo 1 3 blade runningetwin 1995 350.mags with 750 edelbrock carbs mild cams 60 over minor head work done alpha one outdrive 1.50 ratio no mid range at all anyone think they can help
Rock Sinfrazio is offline
Old 07-09-2021, 12:58 PM
resurrected's Avatar
I had an old 233 with stock 260's. It had 19" REV 4's, pulled hard from idle to top end. Can't remember what the top speed was but it wasn't crazy fast.
resurrected is offline
Old 07-09-2021, 01:36 PM
SB
Received 1,017 Likes on 429 Posts
What is your WFO and trimmed rpm now ?
SB is online now
Old 07-20-2021, 08:43 PM
Rookie's Avatar
What is the pitch of the current props? Did it run before all of the work?
Rookie is offline
Old 07-26-2021, 05:36 AM
No mid range...are you going by AFR or seat of pants dynamometer? My Quickfuel 750 has a hole in the fuel supply at 3700 RPM. I'm working on it now. I just went up to a 6.5 power valve from a 5.0. If that gets me part way I can go higher. And can add size to the power valve channel restrictions.
With Edelbrocks you would use a softer spring to bring in the enrichment sooner, and a skinnier rod +/ or larger jet to add fuel...If you were having my issue.
NHGuy is offline
Old 07-26-2021, 10:08 AM
I misspoke, With Edelbrocks you would use a stiffer spring to bring in the enrichment sooner
NHGuy is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
