-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Revolution 14.6x19P vs 3-B something? (https://www.offshoreonly.com/forums/prop-talk/379230-revolution-14-6x19p-vs-3-b-something.html)
AllDodge 05-11-2023 05:23 PM
Just discussing options
Current Props are 4-blade Revolution 14.6x19P both Left and Right hand, twin OB
Looked the props up and these are over $1K each and are stainless steel
Looking at others like Enertia ECO 3-blade 15x21 are X7 alloy and findings say they are 30% stronger then SS
Also looked at Marage + and Hill Marine
Thinking that the larger the diameter the less drag and more bow lift. Don't see needing all the stern lift from a 4-blade. More docking control with larger diameter and more pitch
Boat is a Chaparrel 280 OSX with twin 250 Mercs
Docking control is bad but manageable. Get more pitch and larger diameter then should get more thrust when prop is engaged
Trash 05-13-2023 02:02 PM
Couple of points: The blade area on a Rev 4 prop is MASSIVE. It is significantly more than nearly all 3 blade props. I don't feel the Rev 4 is necessarily a stern lifting prop, but rather with its large blade area (holding power) and long tube it makes it very responsive to trip inputs. Each blade on a Rev 4 is over 28.5 sq in of surface area, compared to a comparable 3 blade which is about 23 sq. in of blade area each.
In short the only advantage I can see by switching to a 3 blade would be more top end speed.
AllDodge 05-13-2023 02:07 PM
Thanks appreciate the input
