Resto has began! 1988 Image / Ocean express 31 cat TONS OF PICS
#131
Very Nice Congratulations, that is great news!
#134
Crazy Energy
1 Post
First start up & idle:
http://www.youtube.com/watch?v=QTXLpupHrw4
First pull after warm up:
http://www.youtube.com/watch?v=_W9IjGseAOQ
I'll have to admit that's the first dyno I have ever seen parked next to a shower stall.
#135
So today was the big day!!
First pull 3.5in pulley on pump gas 29deg. timing 571hp @ 5900 & 566 ft-lb @ 5100 a bit lower then expected but I was still happy!
2nd pull 2.85 pulley same gas & timing, 611hp @ 6000 & 589 ft-lb @5000.
He only ran then to 6200 being a 377ci they should be slightly lower RPM & little torque monsters.
Gonna get the frickin fittings for the boost gauge & a 2.66 pulley & see what that does!
Still on the stand he is confident he can get it to 630hp with a slight carb tune little timing & some more break in time. Biggest problem I had was didnt have the correct fitting for the boost gauge so I have no idea were we were at with boost, Ill know when we dyno the other one when I get back from Mexico in two weeks! I think its good right there had a perfect two thread heat range on the plug beautiful golden brown burned right to the start of the bend on the plug. I didnt know much about air/ fuel mixture but the meter said 12.1 at WOT oil pressure 70psi @ idle 90 psi at WOT.
Im dont know very much about high performance engine but WOW did that sound awesome!!
He also had a 830hp BBC all aluminum on the dyno that thing was incredible made mine sound like a Honda Spree..........
I didnt take a video of the 2nd pull, I will on the next engine witt the smaller blower pulley it really screams!
#136
Registered User
Thanks guys cant wait to hear it on the water!
This might have been causing some issues haha!!! If you look close its also cracked on the bridge between both seats.
#138
Registered User
Lmao I know, I was also a little curious about the shower. He said after 60 years of engine building his wife was sick & tired of scrubbing the grease out of the carpet & house shower.
#140
NICE! Looking forward to hearing some boost numbers and dyno pulls with the smaller pulley. But it sounds like you already have a nice setup going in. High reving light weight going into a light weight race boat! Its going to SCREAM!
