-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   Chevy 350 (5.7L) 260 HP vortec upgrade (https://www.offshoreonly.com/forums/restorations-upgrades/314968-chevy-350-5-7l-260-hp-vortec-upgrade.html)
dwiddowmaker 07-11-2014 08:55 AM
I highly recommend a beehive spring kit. There is a kit around that will get you to .525 lift with no machining, and .550 with a little grinding you can do yourself. Did I mention they are dirt cheap?
NateS 08-18-2014 04:28 PM
Just want to wrap up this thread with results...
After waiting 3 weeks for my intake to come in, and a week of vacation, i finnaly got the boat in the water yesterday... I didn't change the cam, just slapped on heads and intake.
This is what i found for an exhaust valve on #8... no way that was sealing... compression was down to 35psi
http://www.offshoreonly.com/gallery/...19682&cat=3071
now compression is 175 psi.
Boat with 3 people, 3/4 tank, and a 14x19"pitch stainless prop I was able to get it upto 56MPH (GPS) and 4700 rpm.
before the upgrade I was lucky to hit 48 mph with the same set up at 4100 rpm.
Time to throw on a 21 or 23 pitch and see what I can get. you can feel the power difference, and it is a bit louder too...
as far as the upgrade went... the oil dip-stick woudn't fit between the heads and the exhaust manifold. Had to re-bend it to come out on the outside of the manifold (not sure if they make a 1/2" spacer that fits between the head and minfold to space it out). Can't get the valve covers off without loosening the exhaust manifolds a tad to tip them away, but not a bit deal. Also lost the ignition coil mounting location with the intake upgrade, so I ended up mounting that on the rear side of the driverside head. No more choke on the q-jet, may have to upgrade to an electric one... Overall not a bad upgrade. I'm very happy so far. I'm hoping with the correct prop, minimal gas, and just me in the boat I can get it over 60mph.
Thanks for all the info. OSO is the best!!!
the heads and intake i used are:
http://www.summitracing.com/parts/nal-12558060
http://www.summitracing.com/parts/edl-2516
head and intake bolts are ARP, and i just got soem steel valve covers and bolts. All Felpro gaskets!
BlownScarabI 08-18-2014 09:17 PM
I have a complete vortec engine with fuel injection, and vortec heads intake cam harness. block is cracked. make me an offer
donzi matt 08-18-2014 09:22 PM
350 mag mpi setup? Include ECM?
BlownScarabI 08-19-2014 05:11 PM
yes, mpi l shaped manifold, includes ecm, engine ran great block cracked
donzi matt 08-19-2014 05:22 PM
Tried to PM you, mailbox is full. I'm interested in the whole motor.
BlownScarabI 08-20-2014 06:43 AM
i'll clean out my mail box, sorry.
abmotorman 08-20-2014 08:40 AM
Why did the block crack? Froze? Do you know where it is cracked?
BlownScarabI 08-20-2014 11:04 AM
Froze, side water jacket
