-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   Carbs? (https://www.offshoreonly.com/forums/restorations-upgrades/342339-carbs.html)
88corsair 10-31-2016 11:26 AM
Carbs?
I see they sell a marine carb and normal carb? What's the difference in them?
bck 10-31-2016 11:38 AM
I believe the main difference is they have j- tubes instead of straight vents and they might also set it up differently (jetting/ acc pump cam etc.) for marine use.
vintage chromoly 10-31-2016 11:41 AM
Sealed throttle shafts.
Most have "j" vent tubes, but there is no requirement to have "j" tubes in a marine application.
sprink58 10-31-2016 11:55 AM
I always thought the "J" Tubes were to dump excess fuel back into the intake in the event of a sticking float ?
Full Force 10-31-2016 01:13 PM
Yes but not a law to have them.
bck 10-31-2016 05:15 PM
The whole topic seems to get a bit murky. I'll bet if you could manage to actually find all the info and interpret it there'd be differences between what the coast guard wants vs the insurance industry vs whoever else had their fingers in it. It'd likely get more confusing when figuring out if it applies to individuals or manufacturers or professional repairs vs your own repairs. Fuel leaks into the bilge seems to be a big no-no, so I'll bet j tubes are high on someone's list. I had to look into this once upon a time regarding some fuel lines, but that's a different story.
CDShack 11-01-2016 01:11 PM
I had a set and besides the J tubes, they had "spring-loaded" bowl screws. Screw top--spring---screw bottom. I assume the spring was to absorb shock and keep the bowl screw from loosening and leaking fuel. The J tube is to dump overflow into carb instead of all over the place of course. Other than that, I never found anything any different with them. (the 750cfm in a marine form is 715cfm---supposedly that's how much cfm the J tube blocks)
vintage chromoly 11-01-2016 01:41 PM
Problem with "j" tubes is that unmetered fuel can get sucked out of the tubes and go right down the throttle bores.
Again.....NOT required by the USCG.
CDShack 11-01-2016 03:43 PM
True. It's funny what you remember.
There was Speed Shop chain now defunct (can't remember--was Yellow building with brown stripes--anybody?) Any way, I went in and started talking about carbs. We spoke for 30 minutes, picked out 2 carbs, and he asked what I was going to put 2 850's on. I said, "a twin engine boat". Holy cow, you thought I had shot this guy's dog. He wasn't going to sell me these carbs because they weren't "marine" and I was crazy for even thinking about using these, and we went around and around until finally I just told him to keep the damn things, I'd order them somewhere else. I've NEVER run marine carbs, and it's been fine.
vintage chromoly 11-01-2016 05:36 PM
Super shops?
CDShack 11-02-2016 02:24 PM
THANK YOU!!! It's hell gettin' old!
