| dereknkathy |
08-03-2017 06:12 AM |
You will not find a single piece of glass that fits your existing windshield. I bought a 2000 crownline needed the same thing. I bought a 90 regal hulk for the windshield and made it fit. It is the only way to do this. You hafta install the 2 curved pieces, then if width is right your folding center flat glass. If width is wrong, you must fab a new center piece. Use the 2 uprights from new windshield as they are correct fit for new curved pieces. Then get width with just about any scrap windshield frame you find. The sides then have to be fabbed using the bottom piece that fits your boat and hopefully the upper pieces that came with replacement windshield. I ended up usong whole side pieces from the crownline and cutting them to fit the new, slightly liwer regal windshield. I have access to a free 94 crownline 22 bow rider here in jersey. If it is close enough to you it would be worth considering. Price is right. Then you need plexiglass to cut for any flat glass you had to fab frames for. The color is 2111. That is the light coke bottle green they all are. The flat pad the whole windshield mounts on has an inch or so of width you can go wider or skinnier without anybody (but you) noticing. It is easier if you can put it in the same place as you don't hafta fix screw holes that are exposed.
